file_write RCC Worker
Application RCC worker implemented in the C language version of the RCC model. Newer RCC workers are usually implemented in the C++ language version of the RCC model.
suppressWrites: Do not write any data to the file.Type:
countData: Check that the data is a series of 32-bit incrementing values starting at zero.Type:
bytesPerSecond: The data rate during the application.Type:
ulonglongAccess:
inType:
portProtocol:
