Metadata Stressor (metadata_stressor)
Tests an HDL worker’s robustness during development. metadata_stressor is an asset in the ocpi.core component library. Implementations include the metadata_stressor HDL Worker (metadata_stressor.hdl) and the metadata_stressor RCC Worker (metadata_stressor.rcc). Tested platforms include alst4, centos7, isim, matchstiq-z1 (PL), ml605, modelsim, xilinx13_3, xsim and Zedboard(PL).
Design
The metadata stressor component tests an HDL worker’s robustness during development as part of the OpenCPI unit test suite. An HDL worker is expected to accept all valid combinations of metadata without failure, though some are unlikely to be encountered in normal operation. It also may starve the unit under test of data and insert delays between messages. The data starvation may be random or based on a duty cycle. The worker is automatically built into the HDL test assemblies generated by the unit test framework. It can also add zero-length messages (ZLMs) between messages. It passes through the data it receives without change.
A block diagram representation of the implementation is given in Figure 4:
Metadata Stressor Component Block Diagram
Figure 4: Metadata Stressor Component Block Diagram
  <Property Name="enable_give_lsfr" Type="bool" Initial="true" Default="false"
            Description="'true' : MSB of lfsr-15 drives 'give',
                 'false' : use give_duty to set the give duty-cycle."/>
  <Property Name="enable_take_lsfr" Type="bool" Initial="true" Default="false"
            Description="'true'  : MSB of lfsr-7 drives the 'take',
                  'false' : use take_duty to set the take duty-cycle."/>
  <Property Name="give_duty" Type="ushort" Initial="true" Default="1"
            Description="Set the duty cycle for output port 'give'
                1 - constant, 2 (toggle off/on), 3 (1/on, 2/off), 4 (1/on, 3/off)"/>
  <Property Name="take_duty" Type="ushort" Initial="true" Default="1"
           Description="Set the duty cycle for input port 'take'
  <Property Name="mode" Type="enum" Initial="true" Enums="bypass, metadata, data, full"
            Default="bypass" Description="Sets the operating mode of the worker.
            Bypass: worker is bypassed entirely.
            Data: metadata is passed through unchanged but data will have no-ops
               inserted based on enable_take_lsfr or take_duty.
            Metadata: metadata will cycle through all possible valid combinations,
               but data will pass through unchanged (ex. it receives a no-op, it passes a no-op).
            Full both metadata and data will be manipulated."/>
  <Property Name="seed" Type="ushort" Initial="true"  Default="1"
            Description="Seed value for the lsfr, must not be zero. Only effects data
            when either enable_give_lsfr or enable_take_lsfr is true."/>
  <Property Name="allow_zlms" Type="bool" Initial="true" Default="false"
            Description="If true, worker will send zero length messages."/>
  <Property Name="insert_nop" Type="bool" Initial="true" Default="false"
            Description="If true, worker sets all three metadata lines to zero to
            provide a delay between messages."/>
  <DataInterfaceSpec Name="in" Producer="false"/>
  <DataInterfaceSpec Name="out" Producer="true" buffersize="in"/>
  • enable_give_lsfr: ‘true’ : MSB of lfsr-15 drives ‘give’, ‘false’ : use give_duty to set the give duty-cycle.
    • Type: bool
    • Default value: false
  • enable_take_lsfr: ‘true’ : MSB of lfsr-7 drives the ‘take’, ‘false’ : use take_duty to set the take duty-cycle.
    • Type: bool
  • give_duty: Set the duty cycle for output port ‘give’ 1 - constant, 2 (toggle off/on), 3 (1/on, 2/off), 4 (1/on, 3/off).
    • Type: ushort
    • Default value: 1
  • take_duty: Set the duty cycle for input port ‘take’ 1 - constant, 2 (toggle off/on), 3 (1/on, 2/off), 4 (1/on, 3/off).
    • Type: ushort
    • Default value: 1
  • mode: Sets the operating mode of the worker. Bypass: worker is bypassed entirely. Data: metadata is passed through unchanged but data will have no-ops inserted based on enable_take_lsfr or take_duty. Metadata: metadata will cycle through all possible valid combinations, but data will pass through unchanged (ex. it receives a no-op, it passes a no-op). Full both metadata and data will be manipulated.
    • Type: enum
      • Allowed values: ['bypass', 'metadata', 'data', 'full']
    • Default value: bypass
  • seed: Seed value for the lsfr, must not be zero. Only effects data when either enable_give_lsfr or enable_take_lsfr is true.
    • Type: ushort
    • Default value: 1
  • allow_zlms: If true, worker will send zero length messages.
    • Type: bool
  • insert_nop: If true, worker sets all three metadata lines to zero to provide a delay between messages.
    • Type: bool
  • in: 32 bits.
    • Protocol: None
  • out: 32 bits.
    • Protocol: None
The HDL worker runtime configuration parameter DATA_WIDTH_p can be used to set a custom data width for the ports.
  • metadata_stressor (HDL)
    Application worker HDL implementation with a settable runtime configuration parameter for component port data width.
  • metadata_stressor (RCC)
    Application worker RCC implementation that is only a placeholder to fulfill the requirements of the OpenCPI unit test framework. It passes through data without change and should not be included in normal applications, as it provides no real functionality.
<!-- This file is protected by Copyright. Please refer to the COPYRIGHT file
     distributed with this source distribution.
     This file is part of OpenCPI <http://www.opencpi.org>
     OpenCPI is free software: you can redistribute it and/or modify it under
     the terms of the GNU Lesser General Public License as published by the Free
     Software Foundation, either version 3 of the License, or (at your option)
     any later version.
     OpenCPI is distributed in the hope that it will be useful, but WITHOUT ANY
     WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
     FOR A PARTICULAR PURPOSE. See the GNU Lesser General Public License for
     more details.
     You should have received a copy of the GNU Lesser General Public License
     along with this program. If not, see <http://www.gnu.org/licenses/>. -->
  <instance component="ocpi.core.file_read" connect="metadata_stressor">
  <instance component="ocpi.core.metadata_stressor" connect="file_write">
The dependencies on other elements in OpenCPI are:
  • None.
Limitations of metadata_stressor are:
  • None.
The metadata stressor component is tested via the OpenCPI unit test framework. The metadata_stressor.test/ component unit test suite directory contains XML files that describe the combinations of tests. The test cases exercise changes in every property across three cases, though not every property in every case, as that would take a prohibitively long time.
Case 1 - Tests the component with crafted ZLMs and SWMs, backpressure on, timeout set to 120 seconds.
  • enable_give_lsfr = True: use lsfr to vary give
  • enable_take_lsfr = True: use lsfr to vary take
  • insert_nop = True: insert delay between messages
  • mode = full: vary data and metadata
Case 2 - Tests the component with eight byte messages, backpressure on, timeout set to 120 seconds.
Case 3 - Tests the component with a single zlm, backpressure on, timeout set to 120 seconds.
Case 4 - Tests the component with crafted ZLMs and SWMs, backpressure on, timeout set to 120 seconds.
  • mode = data: only vary data
  • mode = metadata: only vary metadata
Cases 5-11 - Tests ending on different message types, message size set to 4, stressormode set to full, backpressure on, timeout set to 120 seconds.
  • insert nop = True: insert delay between messages
  • insert nop = False: no delay between messages
Case 12 - Tests most of the functionality, message size set to 128, backpressure on, stressormode set to full, timeout set to 240 seconds.
  • enable_give_lsfr = False: use duty cycle to vary give
  • enable_take_lsfr = False: use duty cycle to vary take
  • give_duty = 1: constant
  • give_duty = 4: 1on3off
  • take_duty = 1: constant
  • take_duty = 5: 1on4off
  • insert_nop = False: no delay between messages
  • seed = 35: seed for lsfr
Case 13 - Tests the RCC version of this component, which is nothing but a placeholder, timeout set to 120 seconds.
In all test cases, the data is simply passed through the component and the tests are determined to be successful by comparing the input and output files.
