metadata_stressor RCC Worker
Application worker RCC implementation that is only a placeholder to fulfill the requirements of the OpenCPI unit test framework. It passes through data without change and should not be included in normal applications, as it provides no real functionality.
  • ocpi_buffer_size_out
    • Type: ushort
      • Read back: False
    • Default value: 0
  • in
    • Protocol: None
  • Outputs:
  • out
    • Protocol: None
