File Write (file_write)
Writes application data to a file.
file_write is an asset in the ocpi.core component library.
Implementations include the
file_write HDL Worker (file_write.hdl) and the file_write RCC Worker (file_write.rcc).
Tested platforms include
centos7, isim, modelsim, xilinx13_3, xilinx13_4, and xsim.
Function
The file write component writes application data to a file. To use it, specify
an instance of it and connect its input port to an output port of the component
that produces the data. Use the fileName property to specify the name of the file
to be written.
This component has one input port whose name is in, which carries the
messages to be written to the file. There is no protocol associated
with the port, enabling it to be agnostic as to the protocol
of the file data and the connected output port.
Operating Modes
The file read component has two modes of operation: data-streaming mode and messaging mode. These modes are similar, but not identical to the File Read (file_read) component modes.
Data-Streaming Mode
In data-streaming mode, the contents of the file become the payloads of the stream of messages arriving at the input port. No message lengths or opcodes are recorded in the output file.
Messaging Mode
In messaging mode, the contents of the output file are written as a sequence of defined messages, with an 8-byte header in the file itself preceding the data for each message written to the file. This header contains the length and opcode of the message, with the data contents of the message following the header. The length can be zero, meaning that a header will be written but no data will follow the header in the file.
The first 32-bit word of the header is written as the message length in bytes, little-endian. The next 8-bit byte is the opcode of the message, followed by three padding bytes. For example, in the C language (on a little-endian processor):
struct {
uint32_t messageLength;
uint8_t opcode;
uint8_t padding[3];
This format of messages in a file is the format consumed by the File Read (file_read) component when in messaging mode.
Implications for No Protocol on Port
The component’s input port has no protocol specified in order to support interfacing with any protocol. This means that the created data file is formatted to match the protocol of the output port of the connected component.
End-of-File Handling
If the file write component receives an EOF indication, it will interpret it as the end
of data and will close the output file and declare itself “finished”, entering the
finished state. This is useful when this component is specified as the “finished”
component instance for applications, which is indicated by setting the finished
top-level attribute in the application (OAS) to the instance name of a file write
component. Thus, when the file write component writes out all its data and
receives the EOF, the application is considered finished.
Nothing is written to the output file for the EOF indication.
<DataInterfaceSpec Name="in">
<protocolsummary numberofopcodes='256'/>
</DataInterfaceSpec>
<!-- File name to write to -->
<property name='fileName' type='string' stringLength='1024' initial='true'/>
<!-- Does the file contain messages with opcodes and lengths? -->
<property name='messagesInFile' type='bool' initial='true' default='false'/>
<property name='bytesWritten' type='uLongLong' volatile='true'/>
<property name='messagesWritten' type='uLongLong' volatile='true'/>
<property name='stopOnEOF' type='bool' initial='true' default='true'/>
fileName: The name of the file that is written to disk from the input port.Type:
stringAccess:
messagesInFile: The flag that turns messaging mode on and off.Type:
false
bytesWritten: The number of bytes written to the file. Useful when debugging data flow issues.Type:
ulonglongAccess:
True
messagesWritten: The number of messages written to the file. Useful when debugging data flow issues.Type:
ulonglongAccess:
True
stopOnEOF: No functionality; exists for backward compatibility.Type:
true
in: Data streamed to file.Protocol:
file_write(HDL)Application HDL worker that only runs on FPGA simulator platforms. This worker will not run or be built for any FPGA hardware platforms because it contains code that cannot be realized into RTL.
file_write(RCC)Application RCC worker implemented in the C language version of the RCC model. Newer RCC workers are usually implemented in the C++ language version of the RCC model.
<!-- This file is protected by Copyright. Please refer to the COPYRIGHT file
distributed with this source distribution.
This file is part of OpenCPI <http://www.opencpi.org>
OpenCPI is free software: you can redistribute it and/or modify it under
the terms of the GNU Lesser General Public License as published by the Free
Software Foundation, either version 3 of the License, or (at your option)
any later version.
OpenCPI is distributed in the hope that it will be useful, but WITHOUT ANY
WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
FOR A PARTICULAR PURPOSE. See the GNU Lesser General Public License for
more details.
You should have received a copy of the GNU Lesser General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>. -->
<instance component="ocpi.core.file_read" connect="file_write">
<instance component="ocpi.core.file_write" connect="file_write">
The dependencies to other elements in OpenCPI are:
Limitations of file_write are:
All test benches use the worker implementation as part of the verification process. This component does not have a component unit test suite.
