file_read HDL Worker
Application HDL worker that only runs on FPGA simulator platforms. This worker will not run or be built for any FPGA hardware platforms because it contains code that cannot be realized into RTL.
fileNameType:
stringAccess:
True
suppressEOFType:
True
CWD_MAX_LENGTH: The maximum string length forcwd.Type:
ulongAccess:
TrueWritable:
512
cwd: The current working directory of the application (required for HDL worker; cannot be determined automatically).Type:
stringAccess:
out: Data streamed from file.Type:
streaminterfaceData width:
32Protocol:
