file_read HDL Worker
Application HDL worker that only runs on FPGA simulator platforms. This worker will not run or be built for any FPGA hardware platforms because it contains code that cannot be realized into RTL.
  • CWD_MAX_LENGTH: The maximum string length for cwd.
    • Type: ulong
      • Parameter: True
      • Initial: False
      • Read back: False
    • Default value: None
  • cwd: The current working directory of the application (required for HDL worker; cannot be determined automatically).
    • Type: string
      • Initial: False
      • Volatile: True
      • Read back: False
  • ocpi_buffer_size_out
    • Type: ushort
      • Read back: False
    • Default value: 0
  • ocpi_blocked_out
    • Type: ulong
      • Initial: False
      • Volatile: True
      • Read back: False
  • ocpi_max_latency_out
    • Type: ushort
      • Parameter: True
      • Initial: False
      • Read back: False
  • ocpi_latency_out
    • Type: ushort
      • Initial: False
      • Volatile: True
      • Read back: False
  • ocpi_messages_out
    • Type: ulong
      • Initial: False
      • Volatile: True
      • Read back: False
  • ocpi_bytes_out
    • Type: ulong
      • Initial: False
      • Volatile: True
      • Read back: False
  • out: Data streamed from file.
    • Protocol: None
