complex_mixer RCC Worker
Application worker RCC implementation with a numerically-controlled oscillator (NCO) that uses the nco module from liquid-dsp to generate the digital sine wave for the complex multiply operation.
The RCC worker implements the NCO using the nco module from liquid-dsp, which is a free and open-source signal processing library for software-defined radios written in C that is included in the OpenCPI installation. For details on liquid-dsp and the nco module, see the liquid-dsp website.
The RCC worker converts the samples from fixed-point to floating-point numbers in order to perform the math on a general-purpose processor (GPP). The conversion equations are:
\[iq\_float = \frac{iq\_fixed}{2^{15} -1}\]
\[iq\_fixed = {iq\_float}*(2^{15} -1)\]
This conversion introduces a small amount of error in the output data that should be accounted for when using the RCC worker in an application.
The RCC worker also performs a conversion on the phase increment (phs_inc) property to adhere to the the way it is implemented in HDL. The conversion is done in the RCC implementation for the component because the division operation is very resource-intensive in HDL. The conversion equation from the component property to the input property in the liquid-dsp interface is given below:
\[liquid\_phs\_inc = phs\_inc*\frac{2\pi}{0x7FFF*2}\]
  • in
    • Protocol: iqstream_protocol.xml
  • Outputs:
  • out
Utilization
Utilization reporting is not currently implemented.
